Central Canada If you live in the Ontario or Quebec area of Canada and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
HD clutch available
Old Feb 19, 2009 | 08:19 AM
dyolfknip's Avatar
Default HD clutch available
https://www.jk-forum.com/forums/modified-jk-tech-2/heavy-duty-clutch-now-available-73560/
I did the legwork with a dealer out of Toronto guys, this is what we can expect to pay when the time comes.
hxxp://www.performanceimprovements.com/
Old Feb 19, 2009 | 08:40 AM
-MAW-'s Avatar
I drove my buddies stang w/t the dual friction I suggest you don't go with it unless it is a trail rig only
but i'll be going with just the stage 1 once my clutch starts to slip
but thanks for the update I got tired of checking centerforces website
Old Feb 19, 2009 | 10:30 AM
dyolfknip's Avatar
Too much grip?
Old Feb 19, 2009 | 12:16 PM
-MAW-'s Avatar
The dual grip will never slip I found you literally have to slam into gear
But then again his stang had over 500 ponies under the hood
And when you think about it stage 1 holds 30% more I think it is more than enough even with 35s and the extra weight of after market crap we put on
But back to the dual friction the clutch pedal was so stiff you couldn't get any feedback from it. And I would rather have the clutch break rather than an axel shaft so you could at least be towed out
But this is my opinion
Old Feb 19, 2009 | 03:00 PM
WRAITHYJEEP's Avatar
ya had dual friction in my sport compact i would not use it in a jeep for all the reasons MAW said and a clutch that is either on or off equals a lot of stalling when ya want it to slip a bit under driver input.
centreforce is same as LUK clutch which last i know of is the same as the stock clutches in all manual Chrysler products. 30% more grip is achieved by spring compression not so much the material
Old Feb 19, 2009 | 03:05 PM
scbesse's Avatar
You mean in your Neon?????
Old Feb 19, 2009 | 03:54 PM
Captain Hook's Avatar
I've never actually met someone who modded a neon before!
I figured you've been driving Jeeps since Jesus was a cowboy!
Old Feb 19, 2009 | 03:59 PM
whtIwrk4's Avatar
now now guys. Neons need modding too. White lights, fart pipes, blue glow in the dark windshield washer nozzles, yes and even dual force clutches. Scott, please tell me you didn't have neon lights under it.
Spent money modding a neon
Old Feb 19, 2009 | 04:26 PM
scbesse's Avatar
Hey I want the Blue Neon winsheild washer lights for my Jeep. I guess i could get the dual force clutch for my car
Old Feb 20, 2009 | 01:44 PM
2Summer's Avatar
We run the dual force in Chantal's Z28... I wouldn't consider it for a jeep unless you never took it off road... If it was strickly a pavement pounder then go for it, if that's the case drop a ripper shifter into, slam it too the ground and go nutz
