Central Canada If you live in the Ontario or Quebec area of Canada and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
What is this?
Old Feb 10, 2013 | 05:10 AM
KidWrangler's Avatar
Default What is this?
Name:	DSC_0260 (640x424).jpg
ID:	420360I just installed rock rails and when I was cleaning up I seen this O ring that looks like it holds up the muffler ( but muffler is secure ) . Maybe something light weight, I can't tell.
Also after I took the Jeep out to the store I'm getting this knocking or thumping noise for underneath, almost as if whatever the ring was holding is now loose or those 4 washer plates that I had to remove in order to get rock rails on ( rails had that painted grizzly grip on them and couldn't fit over washers )
2 questions, what do those washer plates do? And if they weren't tightened 100%would there be a knocking sound present or is that because of this O ring? Thank you
Old Feb 10, 2013 | 06:30 AM
Biggy's Avatar
I dont recognize the rubber ring. The washers are on now and everything is tight right. I would go over any bolts you loosened and check for tightness.
Old Feb 10, 2013 | 06:44 AM
Sahara_Steve's Avatar
When i put my rock rails on i did have a small clanking sound from one side that i had not tightened enough. My rock rails we're a bit off from the factory holes so i had to bend it a bit. After i tightened it the noise went away so hopefully yours is the same
Old Feb 10, 2013 | 07:54 AM
Do you know what those 4 bolt/washers are doing? What's there purpose?
Old Feb 10, 2013 | 12:10 PM
Biggy's Avatar
Maybe to fill a void or evenly spread pressure. You didnt remove anything permanently to install the sliders correct. Everything went back on the jeep the way it came off so I would just go over everything and make sure its tight.
Old Feb 11, 2013 | 07:26 AM
I had to tighten the passenger front a tad, took it for a drive and heard it clunk once as oppose to a variation of clucks every bump in the road.
And the mystery of the O ring has been solved, typed in the part number in good ol' googletron and it's an exhaust hanger for my other vehicle.
Old Feb 11, 2013 | 02:32 PM
viking's Avatar
When i had the rugged ridge rock rails on I had a squeak coming from one of the washes. It was rubbing on the inside where the body mounts are. could your clunk be that. If so just grind down the washer bait. It took awhile to find the problem but Jim at rockspyder 4x4 found it. A little rub made so much noise.
Old Feb 28, 2013 | 06:14 AM
mrktwatchr's Avatar
keep it ..It will probably fit one of your Faucet cartridges ...
