nj diff shops?
nj diff shops?
hey everyone... i will be installing my 3" lift at the end of the month and will be needing to regear before adding the larger tires. unfortunately i have the factory 3.21 gears and think it would be a little too taxing to add 35's into the mix of things. can anyone recommend a shop in the central jersey area to do the swap? any info would be greatly appreciated. thanks in advance.
thanks for the welcome benmar as well as the recommendation for ok 4wd. i have heard some good things about them. i was hoping to find something a bit closer to me. i am in monmouth county and stewartsville is a bit of a hike. i wouldn't mind the travel if i could not find anything closer. there are not many off road shops around here. could anyone help broaden my search such as transmission shops etc. that do this type of work? thanks again for any info.
thanks for the reply mr. t ... that is a good thought about the dealership. i will have to talk to the service manager there. i know they would probably charge a bit more, but it may be worth the $. i will just have to keep searching until i find something. if i do i'll let you know. thanks again
Kryptonite Custom Works in Paramus,NJ. They have done all the work on mine and I have no complaints. Their prices are very reasonable. I have contact info if you want it, just PM me.
I use OK4WD and I travel from ocean county. They are a great shop. If you are looking closer to home you have NO EXCUSES in New Egypt. I have never used them but have heard good things about them.
