Why does the BB code keep changing?!?!?
Old 03-10-2009, 07:55 AM
DuDz40VT's Avatar
Default Why does the BB code keep changing?!?!?
I feel like every time i go back and look at one of my posts with a picture in it, the picture is no longer there because the address of my gallery on here keeps changing.
for example
sometimes the address is this
https://www.jk-forum.com/picture.php...pictureid=7380
& sometimes the www. is added so the address is this
I'm constantly having to go back and take out or put in the www. to get my pictures to show
Old 03-10-2009, 09:37 AM
doojer's Avatar
Actually, both work:
[img]https://www.jk-forum.com/picture.php?albumid=728&pictureid=7380[/img] shows up:
And so does [img]https://www.jk-forum.com/picture.php?albumid=728&pictureid=7380[/img]:
EDIT: I see you are using the profile gallery, which I am not as familiar with. You might want to use the my.project-jk.com hosting service, where the addys seem to be fairly reliable.
For example, http://my.project-jk.com/data/500/a4.jpg would be this:
I will look into this a bit more....
Old 03-10-2009, 04:47 PM
DuDz40VT's Avatar
"Actually, both work:"
im sorry but no they don't, only the one that is correct works at a time.
I did originally open up a my project jk gallery but found it pointless to have because they took away the ability to put the gallery link under your info on the left. A lot of older members on the forum have that link but I joined last November and for whatever reason that option was taken away.
Having the gallery right here on jk-forum seems like it makes much more sense anyway, i just wish the address wouldn't change back and forth all the time
Old 03-10-2009, 05:28 PM
doojer's Avatar
So, you are saying that you cannot see both images below? Because I can. One's with the www and one's without. Is anyone else seeing only one pic or having this issue? We are having trouble identifying it.
Old 03-10-2009, 05:42 PM
Robar's Avatar
I can see two pics.
Old 03-10-2009, 05:51 PM
MoTec's Avatar
I see only the 2nd pic.
If I'm not logged in I only can see the my.project-jk.com image.
This happens in multiple browsers for me.
Old 03-10-2009, 05:54 PM
Robar's Avatar
Maybe it is a browser setting or something?
Old 03-10-2009, 06:01 PM
MoTec's Avatar
I tried chrome, firefox and IE 7 and had the same result in each:
If I'm not logged in I can't see:
or
but can see the
If I'm logged in I can see only the 2nd and 3rd, above, not the 1st.
This happens in the forum or if I try to load the images directly using those urls.
Old 03-10-2009, 07:01 PM
doojer's Avatar
or
but can see the
Well, that makes sense. Because the first two (which are the same pic) are hosted on jk-forum.com, so you need to be logged in to see them. Whereas my.project-jk.com does not require you to be logged in to see the pics.
Old 03-10-2009, 07:11 PM
doojer's Avatar
This functionality still exists. Go to the USER/CP link up top. Hit "Edit Your Details" on the left and then go down to "Additional Details" and add your gallery number.
HERE:
_________________
Quick Reply: Why does the BB code keep changing?!?!?
