Silver Lake Sand Dunes
I think the sign at the gate states a max tire pressure of 15 psi. That being said the lower the better and I would take the proper gear with you so you can reset a bead should you lose it. It does happen. I hope you have proper gearing with those 35's as well, it makes a huge difference in that loose sand.
Hi-lift jack with a wide platform like a 2x12x12 piece of lumber and a ratchet strap and some on board air from someone in your group.
4.11 gears are not offered on the jk, it would be 4.10. You wrap a ratchet strap around the tire and tighten it down to help set the bead so you can air it back up if you loose a bead.
I did not say anything about beadlocks.
oops! that's what I ment 4:10 , I am not aware of this bead(?) you are talking about? please explain
Ether and a match can also seat a bead.
The best advice is know what you're doing before you go do it. If you have no idea what's going on then you'll set yourself up for failure.
Sent from my DROID4 using Tapatalk 4 Beta
