Great Lakes If you live in the Great Lakes area (Minnesota, Illinois, Wisconsin, Michigan, Indiana and Ohio) and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Aweful grinding moise I can't find
Old Sep 18, 2010 | 06:41 AM
Hitch Buddy's Avatar
Default Aweful grinding moise I can't find
I Did my brakes 2 weeks ago,Well yesterday on the way home from work a very aweful screetching from the rear pass side was going on......
I did the obvious things like check the pads and rotors....checked for rust or small rocks stuck on the rotor......I am working on taking off what seems to be a frozen wheel spacer and see if it's the wheel bearings.
Meanwhile it's undrivable do to the noise.any suggestions?
Old Sep 18, 2010 | 08:03 AM
Warpedguy77's Avatar
2011?
Old Sep 18, 2010 | 08:29 AM
Cpt. Flapjack's Avatar
Check the pins on the caliper. If they get froze, they will prevent the caliper from floating and they will drag against the rotor.
Old Sep 18, 2010 | 08:40 AM
Capt,
I removed the Cali,from the rotor spun it and the noise is still there I havea feeling something got in between the dust shield or the Emergency brake pads are lose,cracked,orsomething in there.....I f I get my wheel spacer off I'm in good shape to check I my need to get a Pully puller or something to remove it.It's pouring out so inbetween rain drops I'll keep you posted.
No, 2008
Old Sep 18, 2010 | 08:45 AM
Hopefully it is just the parking break then....
Old Sep 18, 2010 | 09:17 AM
bstpierre's Avatar
I think he was suggesting fixing your problem by buying a 2011.
Old Sep 18, 2010 | 10:29 AM
Ok the rain stopped long enough for me to find the problem......
As the Good Captain said "hopefully it's the parking brake then".......well YES it is...
All the springs and "crap" inside there was "floating"around and broken.so I will try to eliminate thoose broken parts and go without for now.......Since it's an auto I Never find my self using it anyway.I will fix it one day. now onto the Fluids.....
Old Sep 18, 2010 | 11:35 AM
Glad someone caught it
Glad you found the problem Tony.
Old Sep 19, 2010 | 05:57 AM
Glad it was only minor. That parking brake settup is a pain in the ass to work with.
