Aweful grinding moise I can't find
I Did my brakes 2 weeks ago,Well yesterday on the way home from work a very aweful screetching from the rear pass side was going on......
I did the obvious things like check the pads and rotors....checked for rust or small rocks stuck on the rotor......I am working on taking off what seems to be a frozen wheel spacer and see if it's the wheel bearings.
Meanwhile it's undrivable do to the noise.any suggestions?
Capt,
I removed the Cali,from the rotor spun it and the noise is still there I havea feeling something got in between the dust shield or the Emergency brake pads are lose,cracked,orsomething in there.....I f I get my wheel spacer off I'm in good shape to check I my need to get a Pully puller or something to remove it.It's pouring out so inbetween rain drops I'll keep you posted.
No, 2008
No, 2008
Ok the rain stopped long enough for me to find the problem......
As the Good Captain said "hopefully it's the parking brake then".......well YES it is...
All the springs and "crap" inside there was "floating"around and broken.so I will try to eliminate thoose broken parts and go without for now.......Since it's an auto I Never find my self using it anyway.I will fix it one day. now onto the Fluids.....
