Lining (Rhino or Linex) the tub?
I am thinking hard about ditching my carpet and getting the inside lined from front to back, including cargo area. Getting tired of pulling carpet out to dry. Has anyone had this done in the Metro Detroit area? If so, where? And would you recommend them again?
Thanks!
Craig
Thanks!
Craig
I would suggest doing it yourself and saving a lot of money. I've had mine quoted got from 900 to 1800 to do the tub, that's with me taking everything out. I plan on getting the dupli-color kit or the herculiner kit and doing it next summer. There are some write ups on here that made me think its a job I can do in a couple of days.
If you are thinking about doing it yourself, consider using U-POL Raptor. It is a spray on liner that looks like Line-x. The kit is $100 and includes the spray gun. You just need an 8 cfm air compressor.
I herculined the inside of my CJ5 last year. Make sure you put down a good primer because rust will form underneath if it gets a chance.
The Herculiner is no where even close in quality to the Linex. Have the Linex in the wifes diesel truck bed and that stuff is indestructable !!! There are dents in the bed with no scratches in the linex.
I used the Duplicolor on my rocker panels on the JK. It looks alot nicer, but is no where even close to the Linex in thickness or quality either.
I would do the Linex. I am after tax time......
There's no doubt that linex is good stuff, I just can't swing that kinda coin. Capt. completely forgot about the raptor spray on, thats the stuff I plan on using. BTW you wanna do mine that really looks clean. I'm just saying $150-200 w/ some elbow grease vs $1000, its a no brainer to me.
Raptor Liner. Good stuff. Line-X is a great product but crazy money. My quote $1000!
My advice, way too much attention to the prep. We spent 5 minutes with 60 grit sandpaper and it seemed to do the trick. Definitely remove the sound deadening crap. It sucks, but way worth it.
Haven t had it in long enough to give a really good report. Only been 10 days- so far, so good.
The carpet keeps the heat radiating from the floor way down. When I drove around with no carpet before I sprayed some sections got really hot.
The Raptor liner deadens the sound and lowers the heat compared to the painted floor alone.
I bought some of the thick MOPAR mats and they have been great. Cant even tell so far.
Just Do It!
Thanks!
Craig
Thanks!
Craig
This stuff is incredible....strong as hell, uniform textured look, thick etc. It also made quite a difference in the sound as well...much quieter now without carpet.
I am done with my carpet for good now. Take the time to chisel all of the sound dedening/heat barier crap off the floor boards as this stuff holds moisture and you wouldn't want to seal it under the Line-x.
I have pics in a thread on here somewhere but i can send you more pics if you want.
You will not be disappointed and it is money well spent IMO.
They will have it done in approx 6-8 hours.
