Is there a TeraFlex Dealer/Installer in Northern IL?
I searched the Great Lakes forum and couldn't find the exact info I was looking for.
I am considering going with a TeraFlex 2.5 Coil Lift and was looking to either do it myself or get a quote for having it installed by a professional.
I live in between Milwaukee and Chicago near the WI/IL border and the closest place I could find listed on the TeraFlex site was:
J&L 4WD Center 666 So. Thompson Rd. Wisconsin : Approx. 78.52 miles away. This is a little far to have to drive back and forth if I were to have any issues.
Does anyone know of a non-official dealer that installs these lifts or a place to pick up parts? McHenry Four Wheel drive is only a couple miles away but they deal in BDS systems.
Thanks in advance!
Thanks in advance!
Sorry for the late reply; I have been super busy.
www . attitudeperformance.com
or
www . crosbyautomotive.com
or
Last edited by dburgette; Oct 27, 2009 at 07:07 PM. Reason: non sponsor direct link
No worries, thanks for the reply!
After reading through some of the write-ups and looking over the TeraFlex instructions I think I will take a stab at this Saturday morning. I have all of the tools needed in the garage so I am going to hope for the best.
It is nice to know there are some places around though just in case something goes wrong
You won't have any problem with this. These basic kits are super easy to install. If you do run into anything you can P.M. me. my emails go directly to my phone so I will be able to respond quickly.
Hey. This is a great kit. I just installed it on my jeep last weekend with a help from a couple forum members and its pretty simple. Hope it works out for you.
Did you run into anything unusual during the install that I should look out for?
Also, did you use loctite on all the bolts for the suspension? If so, did you use the blue (242)?
Thanks!
No locktite just a torque wrench, and I will recheck in 500 miles. The trackbars need to be torqued to 130 ft/lbs.
Ouch, sorry to hear about the trackbar bracket. I ordered the adjustable rear trackbar so I wouldn't have to drill the hole for the new drop bracket. I will see how it goes.
The Autozone by me rents out a spring compressor for free, I checked it out today on my way home. I think I will take advantage of it. From what it sounds like it could be handy with the front passenger side spring.
I appreciate the tips, thanks!
You won't need the compressor. When you're ready to put the front right spring on just turn the wheel all the to the driver's side. It will allow just enough room to squeeze the spring in there. That's easier than using the spring compressor in my opinion. But good to have just in case.
