Great Lakes If you live in the Great Lakes area (Minnesota, Illinois, Wisconsin, Michigan, Indiana and Ohio) and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Is there a TeraFlex Dealer/Installer in Northern IL?
Old Oct 30, 2009 | 07:19 AM
NorthernILJEEP's Avatar
Originally Posted by rich1340
You won't need the compressor. When you're ready to put the front right spring on just turn the wheel all the to the driver's side. It will allow just enough room to squeeze the spring in there. That's easier than using the spring compressor in my opinion. But good to have just in case.
Thanks for the tip on turning the wheel all the way to the drivers side.
I have never tried to use a compressor, looks fairly simple. But with that being said, I will try it without it first and then utilize it as a last resort.
I just checked the UPS tracking site for my lift and it is in the 'Out for Delivery' status, my favorite status. Just in time for the weekend!
Old Oct 31, 2009 | 07:05 PM
Thanks again to everyone for their tips. I was able to get about 99% of the kit installed Friday night. Everything went smoothly except for the fact that my kit was missing three bolts, 2 washers and 2 nuts from the shock adapter box.
I didn't go with the spring compressors and just opted to muscle them in myself. I was working alone and estimate the total install time took 6.5 hours.
I do have one question about the E-Brake bracket. Are most folks re-installing the old bracket or just leaving the bracket off all together? I was planning on just reusing the old bracket but I did notice how reusing the bracket could put stress on the E-Brake cables under extreme conditions.
Here are some pics:
Before
After
Old Oct 31, 2009 | 09:43 PM
wildandwillin's Avatar
Here are some pics:
Before
After
Looks good I left my e brake hanger off it puts a bind on the cables. BTY look at your breather tubes and make sure you have slack to allow for articulation. Good job. looks great
Old Nov 1, 2009 | 05:59 AM
Hitch Buddy's Avatar
Yes,
Looks awesome !
Old Nov 1, 2009 | 09:39 AM
My breather tube looks okay for normal street driving, but, yes I do see that it could use an extra couple inches. I believe there was a breather tube mod write-up that I need to take a look at.
Now I just need to continue my search for new rims and tires. The stock rubber looks pretty weak with the Jeep lifted. I really like the stock Rubicon package with the BFG's, but need to start looking a little harder now.
Old Nov 1, 2009 | 10:24 AM
Iam still sporting the stock wheels with 37s. It looks great i my opinion. You could go up to 35s
Old Nov 1, 2009 | 07:52 PM
OIIIIO's Avatar
Looks Great! Glad everything worked out for you.
Let it hang loose. That way you dont have to worry when you flex it out.
Old Nov 2, 2009 | 04:28 AM
Makes sense. I will remove the bracket and the nuts from the studs and store them off.
Thanks again!
