58 CJ5 with a Ford 289.
-meljr
Not sure if I'm breaking rules with posts but:
http://s94.photobucket.com/albums/l1...el_531/Willys/
I started to dig into the engine, Found the whole coolant system is rusted out. Everything else has little problems, but not as big.
If anyone is around socal and knows how to rebuild engines, I could use a hand.
Also, Found a M151 MUTT. It's a real bucket, but might be worth something.
You might wanna check and make sure you have a 289. Most 289s were blue. The 260 was red. There may have been a few early 289s that were red, but I don't think so. I could be wrong. 'Course if somebody's painted it, it could be most anything. However, from a 221 to a 289, you cannot tell the difference lookin at it from the outside.
When my motor died, a 260ci, I just picked up a 302 from a bronco. It was cheaper than building a motor and its still running after 20 years. Jeep don't get a lot of miles.
The 302 will bolt in the same as a 289.
If that is the stock transmission, take it easy. No speed shifts.
Good luck with your new purchase.
