Jeep CJ, Jeepster & Willys Overall Jeep CJ, Jeepster and Willys technical discussion bulletin board forum. This includes pretty much most Jeeps made between 1955-1986.
'84 CJ7 conversion to fuel injection...?
Old Aug 19, 2007 | 05:11 PM
Elritecj7's Avatar
Default '84 CJ7 conversion to fuel injection...?
Hey folks, my wife and I just bought an '84 CJ7 with a 6-258 and 5 speed trans and we love it! It runs but needs some work. So after a month of having it and it stalling A LOT, I rebuilt the carburator and want to know if anyone has a ballpark cost on swithing it to fuel injection? It's of course a project and I have plenty of time to do it all myself but I'm told there's a budget to keep to. Haha.. I want it looking sweet and running better...
I saw the Howell TBI conversion article, which was great by the way, but there wasn't any mention of overall parts cost. (other than the Howell kit is half the cost of the Mopar kit)
Thank you in advance for any advice anyone could give.
elritecj7
Old Aug 21, 2007 | 01:46 AM
jeepsteve's Avatar
http://bustedjeep.com
check out this site, very good write ups. one on a junk yard system and one did the howell. i have wheeled with the howell syestem and it works great.
Old Aug 21, 2007 | 06:59 PM
amc78cj7's Avatar
Fuel injection is a "must" in my opinion When I rebuilt my CJ I decided to go with a TBI Chevy 350. It's a tits setup but ended up costing me WAY more money and time than it would have to rebuild my 304 or a 360 long block I had in the garage and add a Howell setup. That would be the best way to go if you want to save time and money.
Old Aug 28, 2007 | 07:51 PM
Elritecj7's Avatar
Default New/use engine ..chevy
Thanks for the help and info. Someone just recomended I pick up a used 4.3liter fuel injected chevy motor from a 80's model chevy. What do you folks think? I wan't put on 6" superlift and run 35's. And gearing of course. MAybe switch froma 5 speed to auto. anyone out there done something like that?
Thanks, Elritecj7
Old Sep 28, 2007 | 04:35 PM
medbender's Avatar
they run about 1700 -2200.00 for the conversion. check with the local smog laws to make sure it will still pass if you have that sort of thing
Old Dec 11, 2007 | 08:50 PM
CJK's Avatar
CJK
I installed the Mopar kit and couldn't be happier with it! HESCO in Birmingham makes the kit and you can buy it direct from them cheaper than 4WD or Quadratech. The old 258 used to give up at about 3500 RPM. Now it screams right through 5000 still pulling. Actually accelerates UPHILL in 5th gear.
Back when I first bought the CJ I rebuilt the motor and put a Weber carb and MSD on it. You could tell it had a little more power but for the money I dumped in it I was disappointed. After I installed the Mopar MPI kit the test drive blew my socks off! The guy I originally bought it from drove it and thought I had swapped in a V8. It's been up over 13000' passes in CO without checking up.
The big difference between the Mopar and the Howell is the Mopar computer controls the fuel AND the timing and can compensate for altitude etc. The Howell doesn't talk to the distributor and can't adjust as much as the Mopar.
http://www.hesco.us/shop.asp?action=...025&catId=7577
Old Mar 20, 2008 | 01:19 PM
mtruckstuff's Avatar
4.0 head and crank, plus factory EFI. Good stroker combo.
Go to: http://www.geocities.com/JeepI6Power/
Old Apr 14, 2008 | 06:28 PM
biglynny's Avatar
Default Howell here
I have the Howell unit on my '82 CJ7. (We rebuilt the engine at 185k when we did the restoration of the rig.) It has a more agressive cam, true dualed headers, Clifford intake and will climb anything plus when my pal with a V-8 360 ran out of gas I still had half a tank left. My unit runs great -I had a Weber on it and there's no comparison.
Old Apr 15, 2008 | 08:43 AM
BLKRUBI's Avatar
elritecj7
I bought a 4.0L junkyard motor for mine. It was a 2000 XJ engine, with 20,000 miles, that I got for $400. I bought the Mopar harness and ECM (got the part numbers off of Hesco's site) and bought all of the replacement sensors locally. I also had to change FI rail and injectors/ (used for $100). I was basically running a 2000 4.0L with a 1995 ignition system in my 84 CJ. It was very much a Hybrid. Very simple to wire into the electrical system of the CJ too and worked good. It jst needed paint and some heavier rear springs.
