Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
SYE question on 3 inch lift
Old Jan 31, 2012 | 08:35 PM
HIROLLR's Avatar
Default SYE question on 3 inch lift
Looking at 3 inch lifts for my 2000 TJ and have been discussing with a couple local 4WD
Shops. Options offered so far include:
1. Rubicon Express kit
2. Teraflex kit
3. BDS kit
The shop that sells RE and TF warned that I may need to add a SYE to address potential drive shaft issues. He said wait until lift is installed and see IF it's needed?
The shop that sells BDS said there won't be any issues with the drive shaft?
So who's right? Any info would be appreciated.
Old Jan 31, 2012 | 09:06 PM
Cesar's Avatar
I had my TJ with a 4" lift for five years without the SYE kit and not a vibration. However, it has become fairly inexpensive preventative hardware. If you can do it yourself, go for it. If you don't wheel hard or drive too much, then skip it.
Old Feb 1, 2012 | 09:09 AM
Full-Traction Suspension's Avatar
Former Member
2. Teraflex kit
3. BDS kit
The shop that sells BDS said there won't be any issues with the drive shaft? I can tell you our 3" kit will not need it. That being said. The SYE gives good peace of mind knowing you wont have any issues
On a 3" kit you shouldnt need an SYE. Not all 3" kits are equal. A taller one might require it.
Old Feb 11, 2012 | 10:19 PM
Sahara707's Avatar
2000 TJ Sahara. I went with a Rubicon Express Super-flex 3.5" & 1" body lift. SYE & New Drive Shaft. 35" BFG MT K2. Upgraded Tie-rod. Fox Shocks w/Resevoirs. Why do it twice. Good Luck!
Old Feb 13, 2012 | 09:48 PM
HIROLLR's Avatar
Thanks. Appreciate the info.
