Jeep TJ & YJ Wrangler Overall Jeep TJ & YJ Wrangler technical discussion bulletin board forum. This includes all Jeep Wranglers made between 1987-2006 and includes models such as the Unlimited, Rubicon, Sahara, Sport and X.
Will they fit? Mickey Thompson's 35x12.5x15 MTZ????
Old Sep 28, 2010 | 04:29 PM
memphis23's Avatar
Default Will they fit? Mickey Thompson's 35x12.5x15 MTZ????
I have a 92 wrangler (renegade)with a 2.5 spring lift and 2 inch body lift I have always run 33's I am going tomorrow to buy 35's MTZ's unless someone here convinces me it is the wrong thing to do
Old Sep 29, 2010 | 09:41 AM
yjnick95's Avatar
Former Member
You might rub a bit with them when its at full flex. It will be fine.
Old Sep 29, 2010 | 10:50 AM
westchester's Avatar
Ive these tires, at 27psi they measure only 34.25" diameter, so easier fit than other supposed 35s
Old Sep 29, 2010 | 12:50 PM
memphis23's Avatar
man this is making me crazy. tires are sooo expensive now. i just want to get it right
what advantages are there to larger tires vs smaller tires with more travel room? I mean nothing sucks more than knocking off lugs and having to live with it
Old Sep 29, 2010 | 12:53 PM
memphis23's Avatar
YJNick why are you running 33's? instead of 35's
Old Sep 29, 2010 | 01:42 PM
yjnick95's Avatar
Former Member
I went with 33's because im still running 4.10's. 35's kill what little power I have in the 4cyl. Just to much tire for being stock gears.
Old Sep 29, 2010 | 04:17 PM
memphis23's Avatar
thanks for your help
I went with 33x12.5x15 SSR radial Super Swampers
I have the gears (4.56 with lockers and 4.0 high output engine) and transfer case Atlas 2 but I was too worried about travel clearance in the end
this forum is a big help
thx
Old Sep 30, 2010 | 07:31 PM
owtcast's Avatar
You probably did the right thing. I run 35's on my YJ and occaisionally hit the front of the rear fender well. And, I'm running a spring over with a 1 inch body lift. So about 6-7" of lift. The YJ fender wells are just too small.
