D44 front and rear axles
Looking to see if anyone is interested in a set of Dana 44's out of a 09'rubi. 4.10 gears, working lockers. front has been built up w/ evo sleeves, inner c gussets, lower control skids and poly ball joints. the rear is stock. both have riddler covers and 1310 style yokes. they about 55k w/ light wheeling. mostly just road miles. brakes not included. I'm located in VA "Hampton Roads" area. Asking $4K OBO.
My new Core's are en route. Pictures will come as soon as i can take them out. I forget to mention that both will come with poly track bar brackets. the front is the bolt on type. the rear is the type that required some trimming of the rear mount. The right knuckle has also been drilled for a flipped drag link, but the poly sleeve can easily be switched to the under side. Once again, no brakes or unit bearings.
