JK Axles, Gears & Drivetrain This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
D44 front and rear axles
Old 02-11-2016, 03:34 PM
CMEFLX's Avatar
Default D44 front and rear axles
Looking to see if anyone is interested in a set of Dana 44's out of a 09'rubi. 4.10 gears, working lockers. front has been built up w/ evo sleeves, inner c gussets, lower control skids and poly ball joints. the rear is stock. both have riddler covers and 1310 style yokes. they about 55k w/ light wheeling. mostly just road miles. brakes not included. I'm located in VA "Hampton Roads" area. Asking $4K OBO.
Old 02-12-2016, 05:20 PM
TreyJK's Avatar
Pictures?
Old 02-18-2016, 02:03 AM
xp1ik05's Avatar
Willing to sell the front? Kinda local.
Old 02-19-2016, 06:15 PM
jwilson2598's Avatar
Sent you a message on these, I'm close enough to come get both.
Old 02-20-2016, 04:50 AM
CMEFLX's Avatar
My new Core's are en route. Pictures will come as soon as i can take them out. I forget to mention that both will come with poly track bar brackets. the front is the bolt on type. the rear is the type that required some trimming of the rear mount. The right knuckle has also been drilled for a flipped drag link, but the poly sleeve can easily be switched to the under side. Once again, no brakes or unit bearings.
Old 02-27-2016, 06:46 AM
WVjeepman's Avatar
I would be interested in the rear but not for more then 1000.00
Old 02-29-2016, 10:31 AM
SullivanSeptic's Avatar
Saw your looking for a rear axle. Just thought I'd throw it out there. I have a stock axle in perfect shape for sale. $700. Came out of my 2010 with 35,000 miles on it.
Old 03-01-2016, 08:21 AM
WkFish's Avatar
does this have 4:10's? Where are you located?
Old 03-01-2016, 08:33 AM
Sorry, mine has 3.73's. I am located on far South burbs of Chicago. Basically Joliet
Old 03-03-2016, 06:17 AM
Pierpressure's Avatar
PM sent
Quick Reply: D44 front and rear axles
