JK Axles, Gears & Drivetrain This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
Rear rubicon locker
Old Mar 25, 2015 | 01:03 PM
razz924's Avatar
***sold***
This is a new oem rubicon rear locker in box I bought to put in a non-rubi rear and ended up buying 35 spline setup instead. Would like to get 350 for it. Shipping in your dime. Located in York, nebraska.
Old Mar 25, 2015 | 01:53 PM
Tightdog's Avatar
So will it work on a non rubicon Dana 44? And with the axles that your selling? And do you know what gear ratios it will work for?
Old Mar 25, 2015 | 02:28 PM
razz924's Avatar
They should work with 3.73 and numerically taller gears. The carrier bearings are different size from a rubi 44 to non-rubi and was told it wouldn't work but not 100% sure
Old Mar 26, 2015 | 06:09 PM
bidiller's Avatar
Will this work in the front axle ?
Old Mar 27, 2015 | 09:25 AM
razz924's Avatar
I'm not sure if it would work or not
Old Mar 27, 2015 | 09:42 AM
cormac827's Avatar
Don't you have to worry about spline count isn't rubicon 32 vs 35?
Old Mar 27, 2015 | 10:32 AM
razz924's Avatar
Good point. Splines are different
Old Apr 1, 2015 | 03:08 AM
razz924's Avatar
Wednesday bump day
Old Apr 1, 2015 | 11:56 AM
RodCyn's Avatar
Does this include everything.. electro magnetic actuator? Do you have photos/part numbers. thank you.
Old Apr 2, 2015 | 02:16 PM
razz924's Avatar
Here's pictures.
There is a touch if surface rust specs
Attached Thumbnails image-2960913554.jpg   image-2569777602.jpg   image-3281857508.jpg   image-4285634772.jpg   image-2347667560.jpg
