JK Axles, Gears & DrivetrainThis forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
Yes they will, as tire size has nothing to do with aftermarket driveshaft's. You will, however, require adjustible controll arms as the shaft will be too long for stock CA's.
Did you take any measurements before having the shafts built?
as stated in post #8 I bought them for 4" lift on 4door. As long as you have adjustible control arms you can work outside of that range(to what extent I am not sure, and refer to posted shaft lengths
