JK Axles, Gears & Drivetrain This forum is dedicated for the selling of factory and aftermarket Jeep JK Wrangler axles, gears and drive train components. This would include things such as lockers, limited slip differentials, axle shafts, U-joints, drive shafts and complete axle assemblies.
Tom Woods 1310 Drive Shafts Front and Rear
Old May 12, 2012 | 04:48 AM
StrizzyChris's Avatar
Default NEW 1310 Drive Shafts Front & Rear
***BOTH SHAFTS HAVE BEEN SOLD*** Thanks for all the interest folks but these went fast local...Have a good one and hope to see you on the trail!
Name:	drive shafts.jpg
Old May 13, 2012 | 08:06 PM
pastorwug's Avatar
will these work for 35s on a 2011 JKU Rubi?
Old May 13, 2012 | 09:06 PM
Yes they will, as tire size has nothing to do with aftermarket driveshaft's. You will, however, require adjustible controll arms as the shaft will be too long for stock CA's.
Old May 14, 2012 | 02:30 AM
zaknafien's Avatar
Do you have the lengths the shafts were made to?
Old May 14, 2012 | 05:46 AM
Measured them and....
Front is 39 1/2"
Rear is 51"
Old May 14, 2012 | 05:53 AM
JKingAround's Avatar
Were they for a two door or four door with what size lift
Old May 14, 2012 | 06:18 AM
4 door and was going to use them for a 4" lift. Im not sure what lift hight range it would work on. Maybe others can chime in on that.
Old May 14, 2012 | 09:05 PM
MikeReo's Avatar
Did you take any measurements before having the shafts built?
Old May 15, 2012 | 07:30 AM
as stated in post #8 I bought them for 4" lift on 4door. As long as you have adjustible control arms you can work outside of that range(to what extent I am not sure, and refer to posted shaft lengths
Old May 18, 2012 | 11:45 AM
Woodchuck's Avatar
I'm interested in the rear driveshaft and I'm local (92882)
Freddie
951-454-9696
