The 1001st Cobra 75 install
But only the Third one that I've seen done in the center console (I'm sure there are more as I am NOT all seeing
). Anyway I wanted it out of the way and mounting under the glove box didn't look all that sturdy so here is what I came up with. I mounted the remote unit to the inner side of the center console, you can see it on the right side about half way up in the first pic.
I used a couple tiny button head bolts, you can not see them when the console is in place, as you can see I missed on the first hole. Then I ran the short mic cable up through the console support and then through the black center piece, had to drill through both. I did not use the plate to hold the plug grommet, I just drilled a 3/4" hole (smaller than the plate opening) and put the grommet right in the console.
Now all I have to do is find a spot to hang the hand set.
). Anyway I wanted it out of the way and mounting under the glove box didn't look all that sturdy so here is what I came up with. I mounted the remote unit to the inner side of the center console, you can see it on the right side about half way up in the first pic.I used a couple tiny button head bolts, you can not see them when the console is in place, as you can see I missed on the first hole. Then I ran the short mic cable up through the console support and then through the black center piece, had to drill through both. I did not use the plate to hold the plug grommet, I just drilled a 3/4" hole (smaller than the plate opening) and put the grommet right in the console.
You might want to consider a "Gear Keeper" -I don't have one but it looks cool.
I'm guessing you already know about the Cool Tech VersaMount
Originally Posted by MCwired
Yep! Agree with Rooster76.
Although antenna, mount and grounding is key to good swr's.
I've got
Channels 1 and 40 are just below 1.5 and channel 20 is barely above 0.
I've got
Attachment 303763
That's neat,
Yes
I am no expert, but I was just reading the Firestik - Tech Doc Site so I figured I would pass some info along. It said that you should try to get channel 1 and 40 to be as close as possible to the same SWR for the best tune. They also mentioned that you should shoot for under 2 (point 14 and 46 http://www.firestik.com/Tech_Docs/63Things.htm)
That's neat,
Yes
