3rd brake light Antenna Install
Old Mar 27, 2011 | 07:20 PM
  #41
CRNA's Avatar
does your hardtop have a wiper? Doesn't the wiper hit your mount? I also like the centered look, but don't think there is enough clearance for the wiper on my '11 JKU.
Old Mar 28, 2011 | 03:04 AM
  #42
JKU Rubicon's Avatar
Originally Posted by sin52
Dear Lord!
I installed my antenna at the same place on the tire rack, and, I didn't remove the powdercoat
Is it okay? Or should I remove the powdercoat?
Old Mar 28, 2011 | 03:29 AM
  #43
sin52's Avatar
If you're getting good readings I wouldn't worry about it.
Flapwheel would've worked great but I didn't have any handy at the time.
I did it because I didn't want to run a separate ground from the antenna mount to the gate. I did run an extra ground from the gate to the tub just in case the hinges lose conductivity as some have mentioned.
Post a pic (or link) of your install I'd like to see it.
Originally Posted by JKU Rubicon
Dear Lord!
Old Mar 28, 2011 | 03:40 AM
  #44
sin52's Avatar
Here are the measurements of the antenna mount from the top forward egde closest to window. Measurements were taken from the top forward edge of the swing gate.
2-1/4" above edge of swing gate.
9/16" aft of the top fwd edge of swing gate. Used a level and straight edge for measurements.
Hope this helps.
Old Mar 28, 2011 | 03:47 AM
  #45
Well, I don't know if I get good readings... I installed this cb 3 weeks ago, and, there is nobody online in my area. The only thing I hear are the truckers (weak signal) on the highway, very far from my house.
I will go wheeling in about one month with friends. I can't wait to try this small Cobra
Thanks for the reply
Old Mar 28, 2011 | 05:13 AM
  #46
tslewisz's Avatar
He was talking about your SWR readings.
Old Mar 28, 2011 | 05:16 AM
  #47
What is the SWR readings? Sorry, I'm a newbie concerning the cb
(and my brain is slower when I read in English...)
Old Mar 28, 2011 | 07:04 AM
  #48
tslewisz's Avatar
Go here: http://www.firestik.com/Tech_Docs.htm
Read these:
SWR TESTING AND SETTING
* About: What is SWR? [2p]
* About: How to *Measure SWR [1p]
* About: *How to Set SWR [4p]
Old Mar 28, 2011 | 08:28 AM
  #49
Read these:
Great info
Thanks
