3rd brake light Antenna Install
That statement is incorrect^^^ By direct grounding from the mount I am grounded to the entire jeep including the frame. Running a wire from the antenna mount to the jeep frame would not be an improvement but the same
depending on the length of the ground wire as someone posted above it could affect reception.
The tailgate is grounded but some say it isn't a good ground, I can't find anything to support this but a lot of people say it because they heard it from someone else. I swung the gate a bunch of times and didn't have any bad ground issues BUT just in case i ran a 10 gage ground wire 12" long from the gate to the frame through the wire bundle. So I'll never have to prove the theory of the bad ground tailgate.
Been through some horrible rain here in NC. Took apart the tire carrier and 3rd brake light, still no water leaking in. Successful mod c/w.
I mounted mine on top of the light using an "L" bracket and running the antenna wire thru the light stantion, ground strap, works fine
JIMBO
