Antenna info please
Old May 5, 2009 | 04:11 AM
zoomzoomjr's Avatar
Question Antenna info please
I am looking for an external antenna to use my VX-7R in my Jeep. I was looking, and am interested in the Diamond CR320A. I know it doesn't have the 6M, but I wanted a separate ss whip for that anyways. Would it be possible to mount this on the back near the spare on one of the mounts made for this, and then put the 6M on the other side of the tire carrier? Can I use a duplexer, or something else to combine the antennas to the radio? I will be keeping the dual CB whips up front, which is why I was thinking rear for HAM. I will also have the power running on different sides of the Jeep to cut down on any possible interference. I am not planning on getting any other bands in the near future (year or so).
Please let me know ANY ideas you have!
Old May 5, 2009 | 06:42 PM
zoomzoomjr's Avatar
Originally Posted by Ridin' Dirty
You can do all you mentioned but you might want to think about a tri-band antenna instead of runnng two antennas and a duplexer. It's been my experience that the duplexers will attenuate a bit of your radiated rf and if you were running a mobile rig with 50 watts you might not notice a difference, but with the reduced power of an ht you're gonna need all the E.R.P. you can get.
The cr320 is a triband covering 2 m, 1.25 m, and 70 cm. I wanted a dedicated antenna for 6 m, as I have not found one that works on all 4.
Old May 6, 2009 | 12:21 PM
zoomzoomjr's Avatar
that little radio has 4 bands? wow what's this world coming to???
This world has already gotten there... And is still going
I don't know how 222mhz is where you are, but if there isn't a contest going on around here there is no activity on that band at all. It's a shame too cuz it's a great band. How bout getting a tri-band antenna for 50 144 and 440 and use the duck for 222 see how much activity is there.....
The only thing I get around here with the duck, besides the WX is 144. I want the capability to run all of them. I will probably need an amp for the 1.25 as it is only rated at 300mW, but it CAN transmit on it. I also will be looking at an amp for the 144. Take a look at the radio, it is small but full of $#!t (fully sealed/3m for 30 min wide rx, quad tx...).
http://www.yaesu.com/indexVS.cfm?cmd...5&isArchived=0
Old May 6, 2009 | 01:05 PM
zoomzoomjr's Avatar
found one for 220 mhz a mirage 20 watts out dunno if it works c22-a
I have plans for a 30w AN955 from Motorola for 150-175mhz. (from '93)
PDF here
Old May 6, 2009 | 01:44 PM
zoomzoomjr's Avatar
i cant even test it i have nothing with that small of an output on 222
Let me know if you wanna get rid of it, and I can try to see if it works...
Old May 7, 2009 | 01:43 PM
zoomzoomjr's Avatar
Sweet. Done.
Old May 9, 2009 | 01:39 AM
zoomzoomjr's Avatar
Thanks. I'll keep you posted on it's condition.
Old May 13, 2009 | 09:07 AM
zoomzoomjr's Avatar
THANKS!!!
Got it. Will be a few days til I can test it. My antenna is SMA, and I need adapters.
