Antenna Mount.
Last edited by filthy-Beast; Jul 20, 2013 at 10:38 AM. Reason: Link not working right
I like this bracket mounted to the tub by the tail light. CATALOG Main Page (Frame Setup) , best place is a lip mount in front on the hood halfway between the front and the windshield, but that is where my HAM antenna will go. that link does not work correctly always take you to the main page. try this one http://www.rightchannelradios.com/fi...tenna-kit.html I would mount it higher up than that picture. As stated body, tire, carrier reflect the signal back into the antenna which not only limits its travel in that direction but interferes with the signal going in other directions.
Move the mount above and to the outside of the light not where they have it and then you should not lose any height and gain in signal and a better ground plane.
