antenna size
Old May 3, 2011 | 05:12 PM
  #21
J2010k's Avatar
4' Firefly on a Quadratec spare tire mount. This is attached to a Cobra 75 and the SWR is 1.5 it's a great setup!
Old May 3, 2011 | 05:18 PM
  #22
GreenJK07's Avatar
You can also mount on the back side of the license plate holder. That's how I run mine.
Old May 3, 2011 | 06:30 PM
  #23
will16's Avatar
I'm running a 2' firestick but the entire 2' is above the roofline. Works great so far.
Old May 4, 2011 | 05:00 PM
  #24
rripror's Avatar
...4' firestick 'firefly' on the cooltech ultramount w/ cobra wx75, quick disconnect on top of firestick HD spring.
...1.1 on 1, 1.1 on 19 and 1.2 on 40.
...uhh...WINNING!
Old May 4, 2011 | 05:06 PM
  #25
Bingbola's Avatar
Originally Posted by ilflyya
Just got my 4' Firestick II (Tunable Tip) from Northridge4x4.
My current 4' Firestick KW is stuck to a spring mount on the spare tire...can't get it off for nothing! Beware of the spring, although I thought a Spring would be best to provide some "give". When I go to twist off the antenna, the connection just rotates inside the spring. I ran that spring for two years with no issue, now it's junk. Going to a quick disconnect now,
Anyway...enough of that, this is an antenna thread ;-)
Oh, and I'll be doing Toad's homemade antenna holder mod that goes inside, above the rear window
Can some one please give me the thread to that mod?
Old May 6, 2011 | 06:24 PM
  #26
familytime's Avatar
JK Forum Regional Rep
i've been using the 4' and 6' Fire stick for over 30yrs with no problems.Had my 6' near 90 degrees without breaking.They also all hold up well to an extra 500 watts
