Bigger CB question
Old Feb 15, 2011 | 08:57 AM
BKGM Jeepers's Avatar
Originally Posted by tslewisz
I just made a bracket to hang it from the footman's loop. The rear of the radio is steadied with a length of 1/2" square tubing Velcro'd onto the top of the radio and onto the plastic trim piece.
Not a bad approach. How much movement do you get off road? I wonder if I could mod a bar like the pics earlier and tie this mount in?
Great ideas everyone!!!
Old Feb 15, 2011 | 10:34 AM
tslewisz's Avatar
Zero. The bracket loop that goes around the footman's loop is screwed together at the open end and the square tubing and HD Velcro at the back holds it tight. There are no drawbacks to this mounting, other than you can't turn your mirror upside down.
Old Feb 15, 2011 | 02:42 PM
grady's Avatar
Default Mount
Originally Posted by zeppo
I'm running a cobra 29 above the rearview with an arizona rocky road mount and some home made brackets to move it closer to the windshield. Here's a couple pics with said brackets.
Does that bounce around much? From the pics it looks like its only secured to the cross bar?
Old Feb 15, 2011 | 07:37 PM
AK4Dave's Avatar
Has anyone bought a front cage with the overhead spreaders and put a higher powered unit up there?
Jut so you know, as far as power goes, unless somebody has gotten inside a radio with his "magic screwdriver" a small CB has the same amount of "power" and a large CB. I mean 4 watts is.....well 4 watts.
The only other way a standard CB will have more power is when it has SSB in it. Then it can tx upwards of 12 watts.....legally.
Now I'm not saying a larger CB isn't nicer. Bigger, higher quality components can make for a better tx and rx. Modulation, as well as the receivers in larger rigs can be better. It's just that they're ALL only allowed by the FCC to put out 4 watts AM.
Old Feb 16, 2011 | 05:41 AM
conifers4's Avatar
Unless your trying to run an export radio.
Old Feb 16, 2011 | 06:55 AM
AK4Dave's Avatar
I take it you mean a 10m export radio that has been illegally modified to talk on the CB freqs? In which case is not a "CB" radio but is still in reality a HAM radio.
Old Feb 16, 2011 | 08:14 PM
Vegas and Texas shops sell tweaked radios as well as can mod existing radios. I run a tweaked radio in my TJ and a regular unit in my JK. TJ gets more than twice the range of my JK unit. I'd like to get a small standard unit that has been tweaked but couldn't find a good mounting place.
Old Feb 16, 2011 | 08:16 PM
Heavy_D's Avatar
Can you get a close up of how you have it mounted to the footman loop?
