CB Antenna Mount for JK Installed
I too have had the Cobra75 WXST in my TJ for almost 6 years now and like it well enough. If you go this route, I would higly recommend getting an external speaker as the tiny one inside the handset is simply too harsh and not audible enough under noise conditions. Here are some pics of it in my TJ...
The other drawback for me is that it doesn't have a PA function on it. And, if I can find a viable way to mount a full size CB in my JK, I will.
In harsh/hard to hear conditions, I find myself holding the mic/speaker near my ears - which is an advantage over a "normal" CB where the speaker is in a fixed (usually downward) location. But I agree with you that an external speaker is nice - and yours looks very well placed. Does the 75 WXST generate enough volume to drive the speaker well?
That's a nice looking mount. I guess I'll go ahead and order. One quick question though, Is the antenna mount grounded in any way? Do you use a No-ground-plane system or is the mount grounded to the chassis? Awesome looking system, just want to know before I order. Thanks.
Wow, those pictures do a much better job of explaining how this mount works.
But what about selling the mount with and without the antenna. I have a 4' firestick antenna off my old Jeep and can reuse that. I would go for the new cable housing to make sure there are no nicks or kinks in it. I know it doesn't save much money, but it all helps in the end.
Just a thought, maybe there are more people out there like me.
I purchased one and i love it. It is very well built and the customer service i received was excellant. I received it three days after I ordered. I would deffinately recommend this product to others.
Guest
Posts: n/a
WOW,
Really nice job thinking through all the issues on where to mount a CB antenna. And then mfg and mktg the kit, I give you alot of credit! I need a CB to go on the Jeep club runs. I liked your mount so much, I just ordered it. Sweet. Now I will have to search the barn high and low for my old radio shack 40 channel...I think it might have got towed away in the back of my old VW bus...
The antenna will look cool on the JK, but the only thing I am worried about is the added height for the parking garage at work every am. I may end up unscrewing the stick and only use it for the Jeep runs where you need to communicate for with stucks jeeps (hopefully not mine...):toung:
Let's see, tow hooks, straps, CB, big tires, yep I think this is the last item I need. I wonder if the Patriot Jeepers will let a JK run with them?
Ciao! Ted
Ciao! Ted
New member, but I've been looking and listening since i bought my 4d rescue green sahara in November '06.
Today I installed the Ultramount CB antenna kit. I ordered it off Ebay and it arrived a few days later. I finally got around to mounting it today. The directions and pictures we helpful, but I still found it fairly complicated. My other problem was that there were still very small gaps where the mount fits through the license plate assembly. I had to put some silicone sealant to prevent water from getting in there, especially with the amount of rain we get here.
Is there any way to order aside from Ebay ? How about direct orders on here and save the Ebay fees you incure..... hint hint
