CB in Console with Remote Speaker
Old Dec 1, 2008 | 02:53 PM
Robicon's Avatar
Default CB in Console with Remote Speaker
Just thought i'd share a few pics of my install. Mostly ideas taken from this site jumbled together.
Cobra CB, Wilson Antenna, External Roll bar foam speaker, 3rd brake light antenna location, Blah blah blah... pics for a reason.
Old Dec 1, 2008 | 03:13 PM
DKJeep17's Avatar
Is that switch there for the CB? How did you wire that up? I have mine in the center console too, and antenna in the same location... but usually just plug it into the power outlet- - I like the switch idea..
Old Dec 1, 2008 | 03:32 PM
Robicon's Avatar
My switch lights up so it has 3 spade terminals.
Connect power from your battery (or tap into 12V power outlet behind dash) to your "+" terminal of switch
Connect your CB red "+" wire to the "ACC" spade on the switch
Ground your CB black wire ("-" Vdc) and your Ground spade on your switch to frame or the "-" on your Power outlet. Check your ground by testing continuity to the body (unpainted) or to the outer metal of your cigarrette lighter.
If your switch dosent light up it should just be two spade tabs to connect to... if this is the case just put the switch in line with the "+" power out to the red +12Vdc on CB and ground your black wire from CB to metal body (or "-" of power outlet).
Hope this makes sense.
Old Dec 1, 2008 | 03:40 PM
Candlemuse's Avatar
Nice setup. Thanks
Old Dec 1, 2008 | 03:53 PM
DKJeep17's Avatar
Awesome!! Thanks man, looks great
Old Dec 4, 2008 | 04:07 AM
Macavity's Avatar
Is the external speaker mounted at the back of the driver's head?
That pic is too close for me to fully grasp the location.
Old Dec 4, 2008 | 05:32 AM
Skippman's Avatar
Looks like it's in the padding of the roll bar directly above the drivers head. That's actually a pretty good place to put that. Looks almost stock and I'm sure it's easy to hear w/ the top down.
Old Dec 4, 2008 | 07:58 AM
jckid's Avatar
My thoughts exactly. Any chance the OP can post another pic that's not so close up?
Old Dec 4, 2008 | 08:20 AM
ResQGrnRubi's Avatar
x2 please...
Old Jun 21, 2009 | 04:14 PM
Robicon's Avatar
Snap... i never checked this thread since posting it... will get the pic now for those interested. Yes it is located above the driver's head and yes it sounds nice and loud to me being just a few inches from my head.
