CB Install Gone Wrong - Electrical Sys. Going Haywire When I Key-UP
It's not a cig lighter short!!! (that would cause blown fuses)Power Taps are evil. You ALWAYS want to run directly to the battery for Communication equipment. RF and grounding do funny things when undervolted not to mention jeep parts. By using a tap you are robbing something else of power that was SPECIFICALLY designed to have that much power. If you rob peter to pay paul you will end up burnt.
I checked continuity in all places. Everything is fine going off of the Firestik diagrams.
I guess I'l have to hard-wire it.
Could I have done any damage to my electrical system??? It shorted out 3-4 times....
Whats the best rout to hard-wire this thing?
Thanks for all the replies!
R7
R7
Did you DC the antenna and key it breifly to see if it still exhists? and no you did not do any damage.
Most likely what you were taking power from did not like it and went bonkers.....
back to the rule of ALWAYS power Communication equipment from the battery.
If that does not fix it do the other things i said and post back here.
I notice that you are in Dayton. If you want to go wheeling check out the West Chester / Cincy Jeep JKers group on facebook. There are about 20 of us in this area that get together and go ride a couple of times per month.
I might take you up on that.
and yep a dead short would send 12v straight back to the battery and do NOTHING with the cb. the current would head back to the battery and nothing else.
His prob is probably a grounding problem at the antenna or that he tapped into some wires meant for somewhere else. Jk's are finicky and need SPECIFIC amounts of power to specific systems you go robbing power from them you will have exactly this happening.
I have seen people put Cig lighter ends on cbs and get them to work by plugging it in. I have seen people tap into the cig lighter wires before with success, But doing it any other way than a direct wire opens you up to things like this. Sometimes you get lucky and it works. Most of the time it doesn't.
