CB Issues :/
Old Jun 10, 2014 | 07:38 AM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Originally Posted by arjeeper
All that said, it's still most likely an antenna system issue. Swap back to the Midland and test. That will allow you to isolate the problem to radio vs antenna system.
Honestly, I believe it. I've had so many issues getting my setup right, I wouldn't be surprised at all.
Old Jun 10, 2014 | 01:03 PM
Gforce!'s Avatar
I checked my swr just now (radio acting up as usual) it's through the roof. Where should I start? Cable, antenna, links? I have two right angle connectors on my setup. Coax should be fine, it's a year old. I checked my antenna ground yesterday, it's fine.
Old Jun 10, 2014 | 06:49 PM
arjeeper's Avatar
The SWR will be a serious problem and It's almost 100% the antenna system.
Start by disassembling and reassembling. Test again.
I'm guessing you're saying your tested the ground for electrical conductivity. That's not necessarily a good test for the RF ground.
Also, the coax age doesn't make it a sure thing. A pinch in some coax or a cut in the shield and even a one day old coax could be shot.
Check the mount assembly. Look at the instructions to ensure isolators etc are installed correctly.
Old Jun 11, 2014 | 02:44 AM
Gforce!'s Avatar
Well, how should I check for good ground, if not from an electrical standpoint? Also, what are isolators?
Edit: I remembered this morning to check one of my angle connectors. It came apart on me once when I was setting my cb up. I wiggled it back together a bit and immediately got signal. Whether that's the only problem or not is debatable, but it was at least part of it.
Old Jun 11, 2014 | 04:24 AM
Mike Davis's Avatar
My guess is that the microphone is "almost" compatible and it isn't switching from transmit to receive correctly. Try a mic that is made for the new radio.
Old Jun 11, 2014 | 04:37 AM
arjeeper's Avatar
Check out this site for info on mobile radio practice. Great resource. http://www.k0bg.com
Remove any connectors you can. It sounds like that's the problem.
Old Jun 11, 2014 | 07:24 AM
Gforce!'s Avatar
It's actually a cobra mic that you can order through the small catalog in the back of the instruction manual we're good there.
Old Jun 11, 2014 | 07:25 AM
Gforce!'s Avatar
Check out this site for info on mobile radio practice. Great resource. http://www.k0bg.com Remove any connectors you can. It sounds like that's the problem.
Thanks for your help, man!
