Cb mounting
Old Feb 20, 2012 | 07:53 PM
jkkrawler's Avatar
Yea I'm thinking I'll be putting it up above the mirror I'll have to hunt down those 90 degree connections they look like they make life easy up there lol
Old Feb 20, 2012 | 07:58 PM
robsjeep9's Avatar
JK-Forum Ambassador
Originally Posted by JKSLEEPR
In my 2010 I mounted it on the passenger side of the console. Easy access, out of the way. No extra holes in the interior.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280441"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280442"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280443"/>
x2 that's where I put it, never gets in the way and easy access too as you said.
Old Feb 20, 2012 | 08:02 PM
robsjeep9's Avatar
JK-Forum Ambassador
I was worried if mounted above the mirror would water leaks from either top get into the radio? Beside the passenger console I could cover it up easier too if water ever became a problem.
Old Feb 21, 2012 | 03:30 PM
jkkrawler's Avatar
Hmmm now I dont know what to do I like it above the mirror but it just seems easier on the console
Old Feb 21, 2012 | 04:22 PM
robsjeep9's Avatar
JK-Forum Ambassador
Try the console if you absolutely hate it then move it..... You'll be left with a couple small screw holes but no biggie.... Plus you won't see them, your passengers will. Lol
ID:	280868   Click image for larger version
Old Feb 21, 2012 | 04:39 PM
Patman's Avatar
I have the cobra 29 mounted to the passenger side of the console, but I used an existing mounting bolt and did not have to drill any holes. I will try to take a picture shortly
Old Feb 21, 2012 | 05:45 PM
bgall's Avatar
I attached clips below the glove box so the CB can be removed easily. Works great.
Old Feb 22, 2012 | 05:42 AM
Patman's Avatar
Default cb mount pics
Here is the left side mount. It is simply a metal bracket attached to one side of the radio and bent like an "L" at the end to clip it under the trim:
The other side has a similar setup, but the end of the bracket is bolted down with the bolt that holds the dash down:
Here are some mounted pics:
Old Feb 22, 2012 | 01:28 PM
jkkrawler's Avatar
Yea I'll just do that then looks easier for mounting and running the wires
Old Feb 22, 2012 | 04:54 PM
Twins07's Avatar
I used a piece of 1" square stock and made this mount myself. Hard top works won't know if the soft does till spring, but not anticipating any problems.
ID:	281210   Click image for larger version
ID:	281211   Click image for larger version
