CB noise
Old Sep 8, 2010 | 01:21 PM
KenB1010's Avatar
Originally Posted by Bullfrog
Yo Ken how are you doing, sorry to here of your noise problem, LOL just turn down the volume. Secondly try running a jumper ground wire from the radio conection wire to your battery directly, see if this improves your noice issue. Maybe even thicker shielding ground wire. My 4 cents sir have a good day
Hi Bullfrog, I'm doing great. Got Mitchell all moved in to his college apt. last weekend. I would have much preferred being up in Monache with the group though.
With the ground jumper, are you talking about running the radio ground all the way back to the battery or running the radio case to ground?
I did more research and talked to Walcott again. When I disconnect the antennea from the base the noise goes away. Also when I connect my old antennea (the one that you and I tried to tune in moab) I still have no noise. I may have an antennea problem. I'm going to return the firefly and get a new one. Untill then I'll try to tune the 3' firestick for this radio.
Old Sep 8, 2010 | 01:30 PM
KenB1010's Avatar
OK, will do.
Old Sep 8, 2010 | 01:34 PM
Jerrod710's Avatar
Where do you have the antenna mounted. Antennas have to have a good ground too. They need to be mounted to good solid metal surface. Some guys have grounded their antennas to the frame with a wire. Inquire with your cb shop about this and see what they say after you tell them how and where your antenna is mounted.
Old Sep 8, 2010 | 01:42 PM
KenB1010's Avatar
I just installed the Teraflex tail gate antennea mount. I used a grinder to remove the powder coating around the bolt holes and the bottem side of where the antennea accuraly mounts. I also ran a ground wire from the mount to a body ground in the tail gate. I varified the ground and checked connectivity with an Ohm meter.
Old Sep 9, 2010 | 06:15 PM
Jerrod710's Avatar
Keep us posted on what caused the problem cause I am curious so I know for future reference.
Old Sep 10, 2010 | 09:46 PM
KenB1010's Avatar
Originally Posted by Mark in Va
Sounds like you have and I might have a similar problem. Seems my CB is actually picking up the RF noise generated from the Jeep CAN-bus communication. The RF static it generates has a cyclic rythym to it at times until you start the engine. Then it becomes "holy s**t".
In my case, it's coming through the antenna. Tried another antenna, antenna ground, and co-ax, I even tried a hand held unit and IT even picked up the same interference. Tried grounding the radio chasis....nada. SWR is "a match".
Does yours start making the noise as soon as you open your door and then stop after about 10 to 15 seconds? Restarts as soon as the key is inserted? Goes to "another level" when the engine is running?
Took it to a good CB shop in my area and they were stumped. They were opening new components up and letting me try them in the shop. Said mine was the only JK they'd had issues like this with.
I haven't had any success finding a fix for mine so I just turn up the squelch about 2/3. Works fine for trail rides, I just can't get out over about 1 mile on the road.
See if you can borrow someone's hand held unit and see if it picks up the static. That was the kicker on mine. I'd be interested to know if your problem is similar to mine.
Mark
I'll check the specifics of your post when I get home. I have a very small amount of noise w/o the engine running, but when I start the engine it goes way up. I have a Wilson 4' antennae on there now and it is much quieter than the firefly, but I still have the squelch knob turned up 1/2 way. I talked to Walcott CB and their going to send me a new firefly and they where also very willing to sell me a 1" thick book about RF interference. I passed on the book, but an internet search for RF interference woth a CB radio doesn't reveal much information. I thought that with all of the Techno types on the site, surely someone would have diagnosed this problem before.
