CB Noise
#41
Originally Posted by AK4Dave
Not trying to be a pessimist, but don't be surprised if the new radio still picks up the noise. Are you running any aftermarket equipment ie...audio, video, computer stuff? And did you actually try any ferrites? Understand that if you can't find the source of the noise all the ferrites you put anywhere else won't fix your problem. How about the alternator.....are you sure it wasn't that?
I know that the chance of me picking up noise are likely but I believe the better product will help. I can't even use the current rig due to noise.
As for ferrites, yes I have them run on everything at this moment. I have it narrowed down to the fuel pump as the most likely source due to the off key and on key.
Regardless it is keeping my mind occupied while the weather still sucks.
#42
Well known issue with the "in the tank" fuel pumps on many vehicles. This fix worked on my friends Toyota. Cheep and easy, you might give it a try..
Home Made RFI Filter
http://97vette.com/sporttrac/rfi_fix/rfi_fix.html
Last edited by ChuckMRN; 02-11-2012 at 08:29 AM. Reason: unautherized link i'm sure, sorry
#43
When it comes to CB radios pessimism is par for the course, so I take no offense haha.
edit: Just read the article about the homemade RFI choke. This is exactly what I was talking about. EXCEPT I said ferrites, when I should have said toroids. My bad for sure....for some stupid reason I was thinking ferrite. I was thinking one thing and typing another. It's been a long time since I've used either, so I do apologize. But I too have used these: http://www.radioshack.com/product/in...ductId=2103979 like the article suggests a number of times myself with good success. I actually still have one in my HAM shack at this time. The other link I posted to "Amadon", and the kits they have also have the toroid material. If your new radio doesn't take care of the noise then you may have to go this route. It should work.
Good Luck....
#44
Granted quality, or "better" quality radios do have better components and filtering as well. So you may get lucky. Most HAM rigs have noise blankers that many times will block certain rfi, but some they won't. Thus the added expense of a better radio.
Good Luck....
Before I drop this fuel tank I'd like to have an idea. I can pre-build the filter then do the drop and splice. Thanks!
#45
You don't happen to know which color wire is ground and which is positive? I've been searching online for wiring diagrams with no such luck unless I drove a TJ.
#46
I have no idea about the wiring. But are you sure you have to drop the tank? Can't you just trace the wires from the tank to a place close by where you can install the filter?
You however make a great point in trying it further down before going through the hassle.
I still need to find which wire is which though. The wiring runs together down the passenger side then across the top of the fuel tank.
#47
I'm trying to get as close to the pump as possible and with the tank being so long there is about 2'-3' of wiring on top of the tank.
find where you want to splice in the filter and take a needle or pin like object and poke thru the insulation into the wire and see which wire is positive and which is ground. This shouldn't hurt the wire and when you go to splice in the filter your going to cut it there anyhow.
just a thought..
#48
this is what I would do.
just a thought..
just a thought..
#49
I have a dc "juice" finder that has a needle type tip and a light that will go on when you find the positive. They are pretty inexpensive...
#50
Well the new Cobra 29and Tuffy overhead console are in. The noise is less than with the Midland but I'm still not happy. Guess its now on to bonding and installing the noise filter. Planned on the filter last weekend but ran out of time after I took so long on the console install.
I love the look however the metal pin that holds the door up is broken. Talking with the guys at Tuffy now to solve the issue.
This just means more fiddling time and I'm fine with that.
