CB Radio - Coaxial Hookup, How to?
I'm trying to hook up my Cobra WX75 with the northridge kit, but I can't figure out how to make this connector on the open end of the coaxial cable, any suggestions/pictures? Thanks, this is what I have..
There is usually a sleeve that you crimp. First you slide the sleeve over the coax as well as the weather shielding (the black rubber boot), and move them out of the way from the end of the coax, next you strip the end of the coax as you've done. Last, insert the copper core of the coax into the end piece, then slide the missing sleeve up to the end piece, and crim the sleeve onto the end. That secures the PL259 end onto the coax. Then spin on the last part of the end, ans slide up the weather shield. Text really does no justice to explaining what you need to do.
scissorz - here's what you do:
first put on the rubber boot and slide it down a bit. It's just a cover for later. he narrow end goes on first. Then you'll put that outer sleeve on the wire and also move it down and out of the way.
Next you'll put the wire up and into the main connector. You'll want to fill up the side holes and end with solder using a soldering gun. It's a bit of pain, but just takes a bit of patience. Once its filled and solid, you twist that sleeve on -- it first secures to your main connector then will secure your connector to your CB base unit.
Feel free to PM me or ask if you need any other clarification.
http://www.cooltechllc.com/
As for soldering... It's a piece of cake. The main rule of thumb is to heat up what you need to solder, first.
So, put the soldering iron near the holes first, and let it sit for a minute, then just apply the solder there. It should get warm enough to melt the solder without touching the iron to the solder.... Works very well.
A year or more ago we used this similar connector. However, the Cool Tech kit now has a mini-UHF connector on the "CB End" of the coax. The diameter of the mini-UHF connector is not that much larger than the cable itself and so it can be routed through the interior grommet quite easily. Once routed, the Cool Tech kit has a screw-on mini-UHF to PL-259 adapter. This is a pretty cool adapter as the mini-UHF screws up into the PL-259 so it looks just like a PL-259 on the end of the cable. No soldering.
Go with a crimp
radioshack.com/sm-no-crimp-solderless-pl-259-plug--pi-2103247.htm
These work fine. Been using them for years with no problems.
