CB Range
Where on the vehicle the antenna is placed makes a difference too. If your ant is mounted at the left rear corner - IE: at the license plate mount - you may find that you can reach our farther to the front right than in any other direction.
Jamie
Jamie
If by "adjustable" you mean an antenna that you set VSWR by loosening a set screw and moving a small segment of the antenna in and out, yes, that's a good thing (much better than an antenna that you cut to length). However, if by "adjustable" you meant an antenna with a tuner circuit (say, an adjustable LC circuit that electrically adjusts the length of the antenna every time the operator changes frequency), then Gaidheal is right: Overkill for any legal CB operation.
Without getting into the power-output issues, one thing to consider with a lot of setups is the antenna array used. Many people use two antennas (one on each mirror for example). This antenna array will normally net a much longer range... but it changes the nature of the radiation pattern such that the range is extended front and rear at the expense of side-to-side.
One antenna will give (depending on terrain, placement - centre of the vehicle *should* be ideal) the same range in all directions. Once you modify the radiation pattern with arrays you can focus the 'beam' for more range but it's a more focused pattern. Trade-offs, eh?
Jamie
Jamie
The CB doesn't have to be modded to be able to get into Australia. During the right time of the cycle, and with good propagation, that little 4 watts could reach out and touch almost anywhere in the world. Unfortunately because of the thousands that are running illegal power, it would be hard to get your signal through. But it is definitely possible.
