CB Range
Old Jul 1, 2009 | 09:11 AM
Gaidheal's Avatar
Default Oh yeah...
Where on the vehicle the antenna is placed makes a difference too. If your ant is mounted at the left rear corner - IE: at the license plate mount - you may find that you can reach our farther to the front right than in any other direction.
Jamie
Old Jul 1, 2009 | 10:04 AM
Mark Doiron's Avatar
Originally Posted by awkragt
... Adjustable antennas help a ton too?
Originally Posted by Gaidheal
... Short answer - yes, adjustable would be great but might be overkill depending on your actual use. ...
If by "adjustable" you mean an antenna that you set VSWR by loosening a set screw and moving a small segment of the antenna in and out, yes, that's a good thing (much better than an antenna that you cut to length). However, if by "adjustable" you meant an antenna with a tuner circuit (say, an adjustable LC circuit that electrically adjusts the length of the antenna every time the operator changes frequency), then Gaidheal is right: Overkill for any legal CB operation.
Old Jul 1, 2009 | 06:45 PM
AK4Dave's Avatar
Originally Posted by Ridin' Dirty
I talked to Australia back in the late 80's with 10 watts and a 102" whip from a Volkswagen Dasher Diesel.....
wasn't that solar cycle great...!!! I think I did it with less than a watt with my homebrew yagi.....great fun.!!!
Old Jul 1, 2009 | 07:05 PM
AK4Dave's Avatar
Without getting into the power-output issues, one thing to consider with a lot of setups is the antenna array used. Many people use two antennas (one on each mirror for example). This antenna array will normally net a much longer range... but it changes the nature of the radiation pattern such that the range is extended front and rear at the expense of side-to-side.
One antenna will give (depending on terrain, placement - centre of the vehicle *should* be ideal) the same range in all directions. Once you modify the radiation pattern with arrays you can focus the 'beam' for more range but it's a more focused pattern. Trade-offs, eh?
Jamie
From what I remember, the two antenna array on a vehicle "CAN" be a waste of time. I say this because for two antennas to radiate "with" each other to actually be a benefit, they have to have the perfect distance between them....(I can't remember what it is, but there IS a formula). And many times this can't be achieved (on the CB freq's anyway) by putting them on both sides of the vehicle because the distance isn't great enough. It's kinda like how a reflector of a two element yagi NEEDS to be a certain distance away for it to enhance the director, or in this case the driven element as well. As I said....."from what I remember", because I'm going way back to my CB days which was a LONG time ago, so I could be wrong. But does this ring a bell to anyone else? I'm thinking the distance between two "CB" antennas needs to be around 8 feet? Probably a simple google search could prove or disprove my theory anyway.....
Old Jul 7, 2009 | 11:10 AM
You can do that a CB that's modded but the FCC is stepping up enforcement with the money from the sales of the TV frequencies.
Old Jul 7, 2009 | 06:27 PM
AK4Dave's Avatar
The CB doesn't have to be modded to be able to get into Australia. During the right time of the cycle, and with good propagation, that little 4 watts could reach out and touch almost anywhere in the world. Unfortunately because of the thousands that are running illegal power, it would be hard to get your signal through. But it is definitely possible.
