Coax fire-ring grounding question
Old Feb 13, 2012 | 06:38 PM
troyboy's Avatar
Originally Posted by hypeiv
I am using a pl259/so239 type but I don't see how the fire ring will help the ground issue. I would go ahead and pick up a nice 10-12 gauge wire and some ring terminals to fashion a ground. Even if you grind the holes for the antenna stud and the screw you still won't be getting that great of a ground on the tailgate... You are eventually going to want to run a ground wire...it will work without ground wire but your swr will be in the low 2.0 range.
Is I could do it over I would have made a metal plate, drilled into the stock bumper put the metal plate underneath the bumper and run a ground wire to the chasis... That would have been beter and cheaper... If I upgrade to a steel bumper that is what I am going to do
ya, I already have the ground wire routed. I'm just waiting for the bracket. Thanks for the info.
Old Feb 13, 2012 | 08:39 PM
hypeiv's Avatar
no problem... make sure you use a nice ground cable. I had a 16 guage cable first and it wasn't good enough... I used to doubt the importance of grounding but after I got a SWR meter and started tuning my antenna I saw nice gains with better grounding.
Old Feb 13, 2012 | 10:07 PM
troyboy's Avatar
Oh great, I used 14 gauge. I hope that is going to be enough. It sure would suck to have to rewire the ground.
Old Feb 19, 2012 | 05:38 AM
ovrthetop's Avatar
Your better off to get a braided ground strap and run it from the tailgate right inside the cab. And with the FireRing stud mount you have to bore out the mounting holes on almost every antenna mount that's made. The hole needed is larger than a std stud.
Old Mar 29, 2012 | 05:46 PM
Whiskeypete's Avatar
doing my research before purchase and install. is it possible to run a strap from a tailgate mount, through the door, to the ground in the sub enclosure. i recall reading there is a ground inside the enclosure. anyone looked at this as an option?
my current planned build is: cobra 29 lx, firestick 4" FSII, cooltech gatemount, firestick fire ring
first CB and install so looking for advice
Old Mar 29, 2012 | 09:40 PM
troyboy's Avatar
That would probably be fine. I've heard others do that but I don't have a sub so I'm not sure. I used a 10 gauge wire and went straight to the frame with it. My swr meter is showing less than 1.2 on all channels. I have the same setup as you but I have the TF bracket.
Edit: oops I have the cobra 75 not 29.
Old Mar 30, 2012 | 05:16 AM
ovrthetop's Avatar
If you read up on most of the forums and CB sites, you will see that a braided strap is better for grounding an Antenna that regular stranded or solid wire. Since its an RF ground and not necessarily an electrical ground, its all about the surface area of the material providing the ground plane. Which is why if you have a vehicle with little to no metal body structure you have a hard time getting a good ground and keep your levels down.
Old Mar 31, 2012 | 06:33 PM
i've seen a mix of pics and just posts. people are running gauge wire from the gate to the body, then a strap from the body to a frame location. i've also seen a few pics of straps on the tailgate to the body. interesting that people get different results with the setups and materials used. i guess it will come down to a trail by error, to find what works best.
