Cobra 75 install done...
Wow, that's an easy install. The antenna install took all of twenty minutes and the radio and coax maybe twice that much time.
I ended up going with a Wilson tunable antenna only because I wanted to buy from a local shop and they didn't carry FireStik. The owner agreed to tune for me but I set the tip at about half it's adjustment range and distance, based on the few checks I got, was about 4 - 6 miles.
I am considering rewiring so I have dual power sources....
Did you check antenna with an SWR meter? You need to check and SWR should be 1.5 or lower or you can cause harm to radio. I have seen them burn up due to wrong SWR. The radios will talk even better once set
Let's see some pics
I'll be installing the same radio soon but not before I finish installing my secondary fuse block and then finishing up wiring my lightforce 170's.
Power comes through the fire wall from the battery.
Ground is on the tub at the passenger foot well.
Unit is behind the glove box.
Antenna snakes along the passenger rocker. There are three or four plastic nut-serts that need to be removed to have access to the where the harness is snaked.. Out the back under the plastic trim on the gate and through the previously unused rubber grommet in the gate to the right of the spare.
Incredibly easy to install.
Only thing left to do is hard mount the remote unit which I left loose so we could more easily get the SWR meter on it.
