Cobra 75 install Questions
Old Jul 17, 2008 | 02:59 PM
wayland1985's Avatar
Default Cobra 75 install Questions
Just curious for all of you cobra 75 owners who mounted the hide-away box under the glove box.
Do you guys have any interference issues??? There are a lot of electronics in that little area (Radio, blower motor, hazard switches), so I want to see before I go nuts.
And is the zip tie install good enough, or should I drill through the metal plate there?
And as for running the antenna cable, does it matter where I route it? Will it pick up interference? Can I run up the roll bar on the driver's side, across the sound bar, and back down on the driver's side windsheild plastic???
Old Jul 17, 2008 | 03:02 PM
dyolfknip's Avatar
I get no interference where it is. I was able to run my cable along the passenger side the length of my 2 dr.
Vehicles are built to have very little EMI.....dont worry about it. Just make sure you antenna isnt shorted to ground and you will be good to go
Oh and I have the zip ties working perfect. Screw into the metal if you want. Just make sure the cover fits back on before you make any holes.
Old Jul 17, 2008 | 09:04 PM
TexsDream77's Avatar
mine is mounted below the glove box on the lower dash panel. Same radio. Which antenna did you buy?
Old Jul 18, 2008 | 02:13 AM
Great... I'll wire it up today (Assuming Fed Ex doesn't postpone again... )
I bought the cooltech setup.... Seemed like a decent deal for a complete kit...
Old Jul 18, 2008 | 02:35 AM
sn4cktime's Avatar
I used the cooltech mount. I ran the wire down the drivers side and crossed underneath the seat with some other wires. I went up along the center console then pushed through to underneath the glove box. I drilled one side into the metal there, and used a chunk of metal strapping and used that for the other side (wish I had pics of it to show) that way it's a little further from the blower there. Don't seem to have any interference issues. Working good so far, nabbing a SWR meter later tomorrow to double check.
Old Jul 18, 2008 | 08:06 AM
bobzinger's Avatar
I am using zip-ties and so far so good. I attempted to drill but didn't have much luck. I ran the cable along the passenger side in my 4 door. Not much extra is under the dash, so it worked out perfectly. I have no interference from the location and my SWR is 1.5 on 1, 19 and 40. (Firestik II 3' antenna).
Pics are in my gallery.
Old Jul 18, 2008 | 08:26 AM
dyolfknip's Avatar
I also have very low SWR. I am using a 4' firestick II
Old Jul 18, 2008 | 04:16 PM
pushntin's Avatar
zip ties worked great and no intereference
Old Jul 18, 2008 | 04:27 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
good ole zip ties ...no probs
good reception and trransmitting in that location too.
Old Jul 18, 2008 | 05:54 PM
Nice...
I started installing it yesterday... but my antenna was late (I hate FedEx...).
I started finishing it today.... but it started raining....
Tomorrow morning before work I'll have to finish wiring her up so I can start calibrating it after work
