Cobra 75WXST 40-Channel CB Radio
Old 06-04-2017, 08:29 PM
kejtar's Avatar
Default Cobra 75WXST 40-Channel CB Radio
Thoughts? I like the idea that I can make almost everything disappear
Old 06-04-2017, 10:32 PM
davescott's Avatar
It's a good radio and all you see us the mic. The guts fit behind the glove compartment and it's a short run for direct power from the battery through the cowl foam plug.
Old 06-05-2017, 10:34 AM
ShutterBug's Avatar
I mounted mine below the glove box. I also mounted an external speaker off the overhead bar of the cage. It's fine for trail use with a good antenna.
Old 06-09-2017, 02:28 AM
Jahamm88's Avatar
I'm happy with mine, and the majority of the guys i run with have them. Make sure you get your antenna tuned after install. Either pickup a SWR meter from Amazon or use a friends, it makes al the difference in the quality of your transmission and reception
Old 06-12-2017, 07:45 AM
CtSeaRay's Avatar
Yeah I think this is the way I'm going to go also.
Old 06-12-2017, 08:15 AM
Skippman's Avatar
I had one for a few months before it shot craps on me. I'd say they probably have like a 5% defect rate judging by what I read on the forum here. Usual point of failure is the connector on the mic lead from the box.
Another option is the Midland 75-822. It doesn't have the nice box like the Cobra does, but it can be used as both a mobile and a hand held.
Honestly, if someone could make a combo of the two, I'd be a happy man. I don't like where they put the external speaker out on the Midland. It's at the top of the radio. I'm assuming they did that for use with a headset when it's in handheld mode. I wish there was an external output on the mobile connector cable.
Old 06-12-2017, 08:24 AM
kejtar's Avatar
Interesting on the Midland - I remember Radio Shack used to make a similar one nearly 2 decades ago (or rather it was a rebranded something ). Problem there was that it really wasn't putting out the power it was supposed to... wonder if it's the same case with Midland...
Old 06-12-2017, 11:26 AM
Skippman's Avatar
You'd be the first I'd heard complain about it. When in vehicle mode it is connected to a full sized aerial which should help with propagation.
I am in no way trying to bash the Cobra. Lots of guys on here run them with great success, I think I just got a lemon. Rather than buy another one, I'm going to give this Midland a try due to it's flexibility. This is the route I'm planning on heading. I can put the external battery pack in the glove box when not in use.
Old 06-13-2017, 03:27 PM
Spank's Avatar
Big fan of the Cobra 75. It's small, stays out of the way, and works perfectly on trail runs with others. Even paired with a tall antenna, you aren't going to get serious range out of it, but it's more than enough for interacting with a group that's with you.
Old 06-13-2017, 04:33 PM
jchappies's Avatar
I had one...It worked okay. range was very limited on a 4ft firestick. It was a little more sensitive to tune also, grounds had to be very good. I now have a uniden 520xl using the same mounts, grounds and antenna and it works better with better range. both have 4 watts...IDK maybe the uniden has a better radio. just my .02
Quick Reply: Cobra 75WXST 40-Channel CB Radio
