In-Dash CB install
#121
Im bringing this back, what did you guys use for install instructions? Just ordered the Cobra WXST and now need to order the double din kit, firestick antenna kit (idk which), antenna mount (idk which) and the mic mount. Will the Veramount work with this CB mic and the double din setup?
#123
So today I started building my new HU and CB mount today. Its similar to this install, however the CB unit I wanted to install was larger than a single Din, so I have to fully customize the install.
I purchased a replacement dash bezel and all the material I would need to mold the dash so its done correctly. It would be so easy to just shove it in there, but my OCD would never be able to handle it... lol
I purchased a few things to make it easier. I've done this type of work many times, but if there is something that can be purchased to make the build easier... I'll take it. These builds take long enough as it is, no sense dragging it out to save a couple of bucks.
So I bought the Metra Double Din dash kit, which is just a couple of brackets really... which I honestly cut up into 4 pieces. I molded 2 to the front portion of the dash bezel. I molded them to the bezel by welding them to the it. Both the stock bezel and the Metra parts are ABS plastic. So I can weld them together pretty easy. I used the other 2 brackets to mount the Alpine HU and the CB together.
I'm removing my stock head unit and will be installing the Alpine and my CB in the dash.
So far I've managed to mold the dash and mount the units together. The next day the weather is better I can do the finish work on it , as its still a little rough and paint it. I'll take some better pictures tomorrow... but for now these will have to do...
#124
CRE-8900 DIN MOUNT Ham/CB Radio
Just purchased a CRE-8900 10 Meter (Amateur-General FCC license required) / 11 Meter (CB Band) radio. Great radio for mounting in these tight spaces..and even has a DIN mounting sleeve available for it. If for some reason the heatsink on the radio interferes (specs say total depth is 215mm or 8.47 inches)...then I'll probably go with the Crutchfield Universal Single DIN mount and mount on top of the dash.
Link to purchase radio: Cre 8900 Am FM USB LSB CW 10 Meter Radio"New" Free Data Cable | eBay
Note that you must have at a "General" or "Extra" Amateur Radio license to transmit on the 10-Meter Band. Enabling 11 Meter CB band on this radio is super easy, via front panel programming, with instructions on the internet.
#125
I know this is a few years old but I am in the process of doing this to our 07' JKU. Do you have any photos of your finished product. I'm using a Pioneer H/U and a Cobra WXSTII.
J
J
#126
Similar threads that might be helpful.
https://www.jk-forum.com/forums/jk-e...le-din-340945/
https://www.jk-forum.com/forums/jk-e...-build-341048/
#127
However the file product looks like this:
#128
You can check out more in my build thread: https://www.jk-forum.com/forums/jk-s...-294425/page6/
Now that is so much sexier than mine! Just finished mine up, will post pics soon.
#129
Well, thank you.. I try. I've been building these types of things for years. So its just the end result of years of practice
Somewhere I have a "how-to" thread around here that shows exactly how to get this result. Although the "how-to" might be for the over head switch pod in thats also in the picture, I build that too around the same time. But I'll look for you. It has all the material list in there too I think. Let me see if I can find it for you.
Look forward to the pictures of yours
#130
https://www.jk-forum.com/forums/jk-w...m-spod-307789/
