Do I need a CB?
Old Apr 7, 2009 | 07:38 PM
Cesar's Avatar
I have one and highly recommend it
Old Apr 7, 2009 | 10:10 PM
AK4Dave's Avatar
Originally Posted by Jerrygee
It works as well as a CB should. The Firestik is a very good antenna; I was able to adjust the SWR to 1.6:1 or less across the band; close to 1:1 in the middle of the band. I know there are a lot of die hard CB fans here but 4 watts of AM has serious limitations. I don't look at CB as a reliable means of emergency communications but it works well enough when you want to talk to others in your group along the trail. However, get little distance between you and your group and you can kiss your communications good-bye.
I have been a licensed HAM since 1983 and with just a hand held and 5 watts of power I am seldom out of repeater range regardless of where I go. Add a high gain antenna and a 50 watt mobile rig and simplex range increases drastically and even more repeaters come within range.
If you don’t want to make a permanent CB installation (with the expectation of the antenna) I think the Midland hand held tapped into 12V’s of Jeep battery power mated to the FireStik is about as good a 4 watts of CB can get.
I agree. And don't forget, as Solar cycle 24 revs up, anything over a couple miles the CB freqs. will be even more hampered. So basically, unless you're pretty much right on top of your wheelin buddies, you won't be able to count on making a contact over all the hash and trash. During the peak of Solar cycle 22 I had a modified CB that put out only a few more watts than the standard 4. BUT, I had a beautiful full sized 5/8 wave vertical strapped to the house up about 50 feet. Even with that great antenna at that height, and with all it's gain, I could only get out a little more than 3.5 miles before my signal was totally covered up. Where the CB freqs. vertually become useless during these conditions.....HAM radio shines.
Old Apr 8, 2009 | 04:03 AM
jmontgomery's Avatar
I ordered the Uniden 510 kit.
