Finding good ground point...
Old Apr 19, 2012 | 10:28 AM
Matthewd5's Avatar
Originally Posted by keithvegas
That'll do it just fine.
Dumb question but what symptoms would I see if that ground wasn't at 100%?
Matthew
Old Apr 19, 2012 | 12:30 PM
bbolander's Avatar
Originally Posted by Matthewd5
I installed the gate mount kit and the ground wire wasn't long enough to make it off of the tailgate...
So I am using the tie down attachment point, I pulled back carpet/plastic and sanded away a good size circle and I terminated the ground wire with a soldered on crimp ring (not sure if that is the name of it but it came with the gate mount kit
Matthew
did the same thing on mine, used the passenger side rear tie down bolt grinding the paint of the body underneath, the ground wire that came with the kit was jus long enough for that, if the gate mount is on the passenger side tire bracket bolts.
