which firestik for my cobra 75 wx st?
Old Jun 9, 2009 | 08:33 AM
revolucion!'s Avatar
Default which firestik for my cobra 75 wx st?
hey y'all. i'm new to CB's and don't kno which firestik to get. i've seen some rated for 900W and 1000W. how do i choose? there's also some other marking 5/8 or 3/8. i have a cobra 75 wx st and plan on getting a 48" antenna. which is best and why?
thanks!
Old Jun 9, 2009 | 05:54 PM
Desert Fox's Avatar
Veteran: Navy
Smile
Your Cobra will put out 4 watts. As far as the antenna goes, if you intend to use a Firestik, just make sure that at least 2/3 rds if the antenna is about the roof line. You might also consider grounding the antenna mount, not the antenna, but the mount.
Old Jun 10, 2009 | 07:50 AM
Hkx3's Avatar
You are saying 2 or 3 wraps of the antenna is above the roof, or 2/3 of the antenna?
Old Jun 10, 2009 | 08:19 AM
guitarguy's Avatar
2/3 of the antenna should be above the roof line for the best performance.
Old Jun 10, 2009 | 08:36 AM
thanks guitarguy! here's what i'm thinking of picking up, is it adequate:
firestik II FS4-R 4' 5/8wave rated @ 900watts
help me out!
thanks!
revolucion!
Old Jun 10, 2009 | 08:54 AM
Desert Fox's Avatar
Veteran: Navy
Smile
The antenna you have selected will be more that adequate for your 4 watt CB.
Installation, grounding (of both the radio and antenna mount) and setting the SWR will be your next challenges. Best of luck !
Old Jun 10, 2009 | 10:28 AM
the tuning / setting SWR is what i'm worried about...
Old Jun 10, 2009 | 10:37 AM
Default what next?
thanks again for all your responses and help. so i got my
1. Cobra 75
2. Firestik II 4'
what all else do i need to get this puppy up and running?
Old Jun 10, 2009 | 11:29 AM
guitarguy's Avatar
That's pretty much the same setup I have (Cobra 75 and 4-foot Firestik).
Now you need some coax and an antenna mount of some kind.
Coax you can get at any truck stop, I believe 18 feet is what everyone recommends. As for the mount, there's many options on that, I went with an Arizona Rocky Road mount, although it's a little pricey for what it is, you can get many ideas on this forum of what people used to mount the antenna.
And don't worry about setting SWR, get a meter for 15$, and it really is super easy, takes 10 minutes max!
Edit: Also, you should get a quick disconnect for the antenna if you think you'll need it. That what I have, it makes it a breeze to mount/remove the antenna when I need to.
Old Jun 12, 2009 | 07:00 AM
thanks again gguy!
