Getting bad SWR reading need help.
Old Aug 2, 2010 | 12:05 PM
  #21
Coley's Avatar
Originally Posted by spleify
So what is the purpose of this? Just to ground the tail gate? Correct me if I am wrong, but all I see is a wire going from the main tub, to the tail gate. Wouldnt it just be better to run the ground wire from the tub to the mount for the antenna?
Thanks
I've got the teraflex mount, which grounds great to the tailgate. I just ran a short strap from the inside of the gate to the tub, which worked fine.
No need to wire all the way back to the mount - a ground is a ground.
Coley
Old Aug 2, 2010 | 12:30 PM
  #22
thom1879's Avatar
Default Getting bad SWR reading need help.
Make sure that you don't have any continuity between your mount and the center pin. Just disco the cable from your radio and stick one end of your meter on the mount and the other on the base of your ant.
