Got the CB installed
Installed the CB today. Tomorrow I'll go to an open area and hook an swr meter up. Happy with the mount. Check it out!
Compact CB in the console
Attachment 492111
Side mount antenna on rear.
Attachment 492112
Attachment 492111
Attachment 492112
Pretty simple really. Drilled small hole in bottom of console. Ran power and ground forward along bottom edge(hidden) of console, through firewall to battery. Antenna wire hidden under carpet, under driver seat, along threshold, then under carpet along top of tub to the rear tail light. I mounted the side mount antenna mount in the taillight compartment. The CB itself is for now mounted with heavy duty Velcro. I will mount with a bracket later. The drill I had access to, to make the pilot holes for the bracket was too big to fit in the compartment. I have smaller drill at home.
CB Model?
Thanks for the post.
What brand did you get? I like the size. What in your eyes were your other options to mount it? Also does anyone know if I get rid of my radio antenna will I lose only radio am/Fm? Since I never really listen to radio anymore. Thinking of mounting CB antenna there is why I ask.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=492111"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=492112"/>
I did a bit of internal brace trimming using a flexible extension on a Dremel with a cutoff wheel. I was able to get the base of the antenna high on the tub. My SWR is 1.2 across all channels with the hardtop. I have a 3' Firefly.
Did you unscrew the tuning tip then back it in a few threads? Make sure to replace the rubber tip when taking the reading too.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=492848"/>
