Great location for CB Radio 2015 Rubicon
I have attached some pictures of where I mounted my uniden 510. Because of its black face it almost looks factory. I also mounted my antenna where my radio antenna used to be. With the satellite radio and 28 gigs of hard drive its makes my radio completely expendable and plus up in the mountains here in Idaho I don't receive radio stations anyway. I hope this might help someone figure out where to put their radio.
What mounting bracket is that and where did you get it? Is it a universal mount?
Awesome. Thanks for the reply. I've been considering getting a CB installed.
Just to clarify what all do you need to install a CB? Let me know if my shopping list is correct or if I'm missing anything:
1. CB radio
2. co-ax cable
3. antenna
4. antenna mount
... is that it? What am I missing if anything?
If I'm buying a CB with a PA function I figure all I would need extra is the PA speaker, correct?
1. CB radio
2. co-ax cable
3. antenna
4. antenna mount
Awesome. Thanks for the reply. I've been considering getting a CB installed. Just to clarify what all do you need to install a CB? Let me know if my shopping list is correct or if I'm missing anything: 1. CB radio 2. co-ax cable 3. antenna 4. antenna mount ... is that it? What am I missing if anything? If I'm buying a CB with a PA function I figure all I would need extra is the PA speaker, correct?
SJ3550, Type 250 stems
SJ3551 Type 400 stems
Both will do the job well. I used it to mount this entire rig in the back of my JK.
If you're not going to use bolts and a bracket then use 3M Dual Lock. The type you want is one of these two:
Cool. I'd probably go with the 250 type if you want to be able to remove it often. It takes a fair bit of force to unlock the 250 so I'd figure the 400 would be semi-permanent mount. If you look here you'll see my ICOM handheld ham radio and GPS mic both mounted to the dash using the 250 type.. and they don't move.
Here's how I mounted my President Harry II CB.
Another pic here.
Another pic here.
