Help adjusting the SWR
Old Jul 25, 2009 | 06:20 AM
RED_RUBI_07's Avatar
Default Help adjusting the SWR
The instructions weren't very clear to me on adjusting the SWR if you all wouldn't mind putting your in.
Old Jul 25, 2009 | 06:47 AM
Mark Doiron's Avatar
The instructions that came with the radio weren't clear? That wouldn't be surprising. Did you try following the procedure about half-way down this page . . .
Affordable Jeep JK Wrangler CB Radio Solution Midland Model-1001Z Write-up
The paragraph on tuning the CB antenna should work for your situation. If not, what's the specific problem/question?
Old Jul 26, 2009 | 05:29 PM
I have an adjustable antenna but I don't have a meter. Do I need one? I guess i'm just looking for someone to dumb it down for me.:confused:
Old Jul 26, 2009 | 08:33 PM
paulp575's Avatar
Default Re: Help adjusting the SWR
Some radios are equipped with an SWR meter as part of the signal strength meter - check your instruction manual for the radio.
And yes, you need to have an SWR meter to check your radio.
If you eventually find one, here's some tips:
1. Ensure you test with your doors closed (don't ask my why).
2. Be sure all your accessories (radio, etc.) are turned off.
3. Be sure you are not near any utility lines (electrical, telephone) as well as any other transmitting and/or receiving antennas.
You have to check on channels 1, 19, and 40.
Old Jul 30, 2009 | 08:00 AM
NHDoberman's Avatar
Pick up a SWR meter from your local Radio Shack. There are instructions that come with it which will help you tune your antenna. I've had my SWR meter for years and use it all the time with tuning friends antennas so it will pay for itself.
