Help! Bizzare CB Problem
Old Sep 7, 2009 | 12:42 PM
rnjstel's Avatar
Default Help! Bizzare CB Problem
Help anyone!
We have a bizzare thing happening with the CB in the Jeep. It recieves fine, clear and happy on the trails.
But, we can't transmit worth a dang. At best people might get a squelchy buzz.
However, if I step out of the Jeep and hold the antenna with my hand we broadcast crystal clear???
I run a short 4 foot antenna in the licence plate frame.
Some sort of odd ground issue with the antenna? Anyone?
Any ideas would be appreciated
Old Sep 8, 2009 | 03:21 AM
myjk's Avatar
Originally Posted by rnjstel
Help anyone!
Make sure you have a good ground to the jeep and there is no short in the coax cable or plug. Just use a multimeter to check it.
If it is not that try a different antenna.
When you grab the antenna you act as a ground.
Old Sep 17, 2009 | 04:45 PM
Chris333's Avatar
yup sounds like the antenna isn't grounded properly
