Help! Cant tune CB radio antenna
Hi. Just installed the cobra 75 cb radio and a Wilson flex 4 antenna on my rock hard tire carrier mount. I have everything installed the way the instructions say and can't get my antenna tuned below 3:1. Are people running a separate ground strap for the tire carrier? anyone running this same set up?
When tuning make sure your outside, with nothing above you... i made the mistake of tuning in my garage and wasted countless hours
Also make sure that after everytime you tune the antenna you put the cap back on (if it has a cap) Make sure all doors and tailgate are closed |
Had the same problem. Ended up having to run a ground to the tailgate and that fixed it.
Originally Posted by medic_23387
(Post 2470646)
Originally Posted by Croce
Thats a good idea, I did that too. Got a battery ground cable from Autozone (looks like a mesh wire in a way i guess) and ran it from the tailgate to the tub, but that was before i realized you cant tune it inside :doh: |
Originally Posted by just JK'n
(Post 2470882)
Would grounding the tailgate help with the grounding on the swing out tire carrier?
Originally Posted by bigT
(Post 2470960)
Have the same bumper (love it) I ended up grounding tailgate to body and used a teraflex mount that bolts to tailgate with stainless steel hardware and tuned out in a large plowed field and have a swr of 1.2 unless around large buildings or power lines. Had to try different mounts and burn one radio up before I hit the sweat spot.
Sounds like you have a ground issue. Moving parts and CB antennas usually don't get along.
I had similar issues and it turned out to be a bad connection at the plug at the opposite end from the antenna. Make sure your ground and center tap have good connections. I only discovered it when I accidentally bent the cable near the box and my readings changed.
Check out the tech section on the firestick website. Lots of good info on SWR, grounding and Jeep info. I know you have the Wilson but, the info is relevant. Post some pics of your mounting / grounding. RF grounding is different than DC grounding. Autozone has a universal ground strap for $6. I had to ground my tailgate and tire carrier to get to 1.2. Take your time so you don't fry your radio.
Did you remove the powder coat where needed? You can't get a good ground without doing so. Sent from my PG86100 using Tapatalk |
